Please help with carb problems...tried everything
Old Jul 1, 2012 | 03:29 PM
ezhoops's Avatar
Default Please help with carb problems...tried everything
I have a kazuma 150 dingo, cleaned carb twice, still dies when i hit throttle. Checked and the throttle needle rises when i push throttle, tried adjusting air fuel screw, checked that tank is vented, etc.
Only thing i now notice is that my throttle needle doesnt have a e clip but im not sure it ever did.
What can i do next?
Old Jul 1, 2012 | 06:34 PM
ezhoops's Avatar
Cleaned everything once more and i slightly bent the part that the float clip sits on. Now the carb leaks gas constantly out of the air exit and the overflow?
Really frustrated
Here are some pics of everything, maybe you can find something wrong.
Old Jul 4, 2012 | 12:38 AM
cesar110's Avatar
I had the same problem once, clean it more! The reason why it dies is because one of you jets are clogged! Get a wire or something and poke it through the holes! Make sure you can see through all the holes!
Old Jul 4, 2012 | 12:40 AM
cesar110's Avatar
Check fuel filter too! Also make sure choke is ok and not blocking airflow...
Old Jul 4, 2012 | 12:22 PM
ezhoops's Avatar
You could eat off my jets, they are spotless.
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
