ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   1) Engine problems.. (https://atvconnection.com/forums/1-engine-problems/)
-   -   Trail Rover 250 atv won't start (https://atvconnection.com/forums/1-engine-problems/353934-trail-rover-250-atv-wont-start.html)
tdubb87 Nov 4, 2013 05:22 PM
I have a 250 cc trail rover atv it won't start. At first it would start up fine with start button. Then after about a month when I pressed the start button nothing happened only a clicking sound. I jumped the starter and fired right up and after running the atv for about 45 mins I could start it with the start button like normal. Eventually it got to the point where the start button doesnt make that clicking noise and when I jump the starter it just cranks but doesnt turn over. Changed the spark plug and nothing. Help please?
brumbear Nov 4, 2013 06:59 PM
Check the plug for spark when you crank it.
Pull the spark plug put it in the boot let it hang down on the motor and crank it over , watch the gap between the plug for a spark if it's there then the issue is fuel or compression if not I'd check fuses and coil and cdi.
BTW get a new batter put it in once you get it running and then make sure it's charging.
© 2026 MH Sub I, LLC dba Internet Brands
