ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   1) Engine problems.. (https://atvconnection.com/forums/1-engine-problems/)
-   -   Falcon 150 won't start (https://atvconnection.com/forums/1-engine-problems/354673-falcon-150-wont-start.html)
Falcon150 Dec 30, 2013 10:42 AM
I was driving my falcon it was running perfect then it just cut out and won't start again.It backfires when I try to start it. It is getting fuel I've swapped the CDI, coil and plug but it made no difference.
Falcon150 Dec 30, 2013 06:14 PM
The engine is a 150 cc gy6:(
Jaster94 Jan 1, 2014 07:01 PM
you need to go through the wiring harness/loom and check all of your quick connects. sometimes they'll back out of each other, while apart, check the blades inside of the quick connects to make sure they're engaged properly. if all of that is good, let's start checking your red kill slider switch.
Falcon150 Jan 2, 2014 08:09 AM
Have now got it running perfectly for about a minute but it then Boggs down and cuts out. It starts again and does the same. The spark plug is flooded and I have cleaned the carb out 3 times
brumbear Jan 2, 2014 05:31 PM
clean your carb and change your plug float valve is probably getting stuck
Falcon150 Jan 3, 2014 04:16 PM
It was rusty connections in the kill switch from when I pressure washed it the other day. Thanks for all your help
Jaster94 Jan 3, 2014 05:19 PM
pressure washers get things real clean, but wreak havoc on electrical parts.
bogging down----that's indicative of lack of fuel/too much air. the ratio is off and what i mean is that you have plenty of air, not enough fuel. SO, pull the jets out one more time and clean them. it doesn't take much to plug them off.
© 2026 MH Sub I, LLC dba Internet Brands
