Viper go Kart with Brake issues!!!!
Old Feb 3, 2014 | 06:53 PM
Littlep2468's Avatar
Default Viper go Kart with Brake issues!!!!
My frist question is how to take the calipers apart? Next… on this go kart there are two disc on the front and one on the back. So there are 3 lines. I have tried bleeding all lines and no luck. I have look for any leaks and none. I did notice the washers on this go kart where a little different. These have a rubber ring on the inside of the washer and all my other honda atv's have brass/copper looking washers. Should i replace them with the brass/coppper ones?
Old Feb 4, 2014 | 10:32 AM
alawoodchuck's Avatar
I have found that the easiest way to take the caliper apart is to remove it from the disc and before disconnecting the brake line apply brake thus pushing caliper out. Or if it's already disconnected I use compressed air to push it out.
What exactly is the brake issue? spongy or just don't work or you have to pump them.
Old Feb 4, 2014 | 12:34 PM
No brakes at all… there is no pressure. Air has to been entering the lines some how… I tried new washers and no luck. I guess i need to order the same washers that were on there.
Old Feb 4, 2014 | 01:54 PM
If the seals in the brake cylinders are deteriorated from age or being dry, the cylinders may just be moving through the fluid and not pushing it. Disconnect at joints to see if you're getting any movement of fluid. Start at the cylinder.
Old Feb 4, 2014 | 07:05 PM
brumbear's Avatar
I don't know how it's set up but I am guessing it's a pedal for all 3 brakes at once? Fist check your master cyl. Do you know how to bench bleed the master?
Old Feb 5, 2014 | 09:27 AM
Zrock's Avatar
Super Quad Patrol
they may just need to be blead again and again and again. I had to do my atv about 4 times to finally get all the air and crap out of the lines. Have you just tried gravity bleeding? Just crack all the bleeders and take the top of the master and just keep it topped up. Took me almost a full bottle of fluid just to do my fronts and get the crap out. I would let it drain for a bit. go for a ride come back and do it all over.
greg74
Sep 10, 2019 03:03 PM
randycraft24c
Aug 5, 2015 02:50 PM
DeFox500
Jul 26, 2015 06:32 PM
Unzzy66
Jul 11, 2015 10:01 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
