ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   1) Engine problems.. (https://atvconnection.com/forums/1-engine-problems/)
-   -   Tao Atv won't move (https://atvconnection.com/forums/1-engine-problems/355428-tao-atv-wont-move.html)
jbergmann Feb 22, 2014 11:11 PM
Tao Atv won't move
I bought a Tao 125 ATV a few months ago that won't move when you put it in gear. I finally got around to putting in a new clutch a couple weeks ago. My kids rode it for about an hour and now it it doing the same thing. When you put it in forward or in reverse you can feel and hear it go into gear but it won't move. I took the crank cover back off and none of the gears are striped. What can it be?
brumbear Feb 23, 2014 07:02 AM
adjust the clutch? is this a semi auto or manual?
jbergmann Feb 23, 2014 06:46 PM
I adjusted the clutch as much as I could. When I took it back apart there was a bunch of metal pieces in the oil screen. Nothing looks broken but the metal had to come from somewhere.
Zrock Feb 24, 2014 08:46 AM
you never answered the above question.
If you never adjusted the clutch properly you may have just shredded the clutch.
jbergmann Feb 24, 2014 04:43 PM
It is a semi. What is the proper way to adjust the clutch?
brumbear Feb 24, 2014 06:15 PM
loosen the lock nut screw the slitted screw in until it stops (LIGHTLY) back out 1/4 turn and lock it.
© 2026 MH Sub I, LLC dba Internet Brands
