90cc chinese quad wont start. cranks but wont fire
Old 05-28-2014, 05:53 PM
ian86's Avatar
Default 90cc chinese quad wont start. cranks but wont fire
Can someone please help.. i cleaned the carb, the jets, spark plug is ok, new battery it turns but wont fire. I tryed spraying quick start but it wont fire.. there is good compression as it blows my finger right off.. checked the wiring all ok. It was stored away for a year. It seems to have a remote lock box on it but fob doesnt have battery in it.
Old 05-28-2014, 09:53 PM
Jaster94's Avatar
just curious, how do you know the spark plug is OK? are you getting spark or not? if you are, you may try a valve adjustment. if you don't have spark, replace the spark plug, check your kill switches.
Old 05-29-2014, 06:00 AM
ian86's Avatar
Hey jaster thanks for getting back to me, i pulled out the plug and put it against the metal and blue sparks, i made sure kill switches were ok 1 at back aswell. It has loads of power but just wont fire
Old 05-29-2014, 08:00 AM
Jaster94's Avatar
ok, now this may sound odd, but i've had this happen before also on a kiddie quad, i changed the spark plug and voila! she fired right up. some kind of phenomena about a double ground within a spark plug. have you tried another spark plug?
Old 05-29-2014, 08:16 AM
ian86's Avatar
Makes sense alright. No didn't put in a new one in yet I should have but just taut with there being a spark it was ok, but what you said kinda making me think now. I will try a new one as soon as I get home this evening. If it I will feel very silly.. I will let you no once I get new plug in..
Old 05-29-2014, 08:22 AM
Jaster94's Avatar
i'm still studying this phenonema, i don't fully understand it, but i have gone through it and some others have also experienced this. don't feel silly if a $3 spark plug fixes it, i hope it does, in the mean time, troubleshooting will still be the exercise and we'll eliminate issues one at a time.
Old 05-14-2020, 10:34 AM
mytquinn66's Avatar
ian86 did the new spark plug work?
Old 05-15-2020, 08:40 AM
rseg80's Avatar
Default Compression
I’m having this issue too. I put my thumb over the plug hole and it pushed it out but it didn’t feel that strong. I borrowed a compression tester and it read 60psi. I’m pretty sure this is too low to start. I’d check your compression to make sure. If you have spark and fuel it’s gotta be compression.
Old 05-15-2020, 09:59 AM
mytquinn66's Avatar
I put in a new spark plug and it started right up.
Old 06-05-2020, 10:27 PM
crabjoe's Avatar
If it's one of those cheap chinese gauges, go look for another gauge to test with. I've seen some show 60psi when in reality it's over 90psi.
RobbyComstock
3) General Discussions..
06-29-2015 11:05 PM
VRRRRT
06-27-2015 09:38 AM
Ragtop
06-27-2015 03:04 AM
RaymondT
05-26-2015 08:14 PM
littleatvr
04-28-2000 02:36 AM
Quick Reply: 90cc chinese quad wont start. cranks but wont fire
