bypass safety switches
I have a fuxin 110cc. I can get it to turn over rather easily.new plug,carb rebuilt etc etc.
it has the brake master cylinder on each handle for the brakes with the brake safety switches. and I have the pull cord kill switch on the rear. can I just unplug the rear kill switch an it will be fine? and on the handle bar brake switch,if I take off the wires,do I leave them open or a jumper wire to make the cdi box read it to start. I think this is my problem with it not starting. thanks |
took the remote kill switch box off and it rattled like rocks were inside.can I just unplug it?
and I do not see a cdi box nor a connector for one.is the remote kill box the cdi also? |
run a test meter across the leads to both switches and test.. find out if they are normal open or closed. If they are open then just unplug if closed need jumper..
I put my meter on them and got nothing.I turned the atv over trying to start and got nothing again. I am still looking for wires where someone may have cut the cdi box off this thing.
