ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   1) Engine problems.. (https://atvconnection.com/forums/1-engine-problems/)
-   -   500CC Chinese ATV won't start (https://atvconnection.com/forums/1-engine-problems/366805-500cc-chinese-atv-wont-start.html)
Kazjag500 Feb 10, 2016 08:05 AM
I have a 500CC Chinese ATV which is a 2007, I have had it for around a year now and bought it off someone down the road. Just about a week ago, I took the rear fender off to clean it and to use some engine shine. But I did use quite a lot of engine shine. And I then put the entire fender back onto the ATV, and when pulling the battery wires into the battery box I was pulling on the wires. And then I attemped to start the ATV. It will crank but that's about it. I tested the spark plug, and it turns out there is no spark. So I replaced the spark plug with a new one I ordered a new spark plug tested that one, still no spark. I then tested the ignition coil with a multimeter and it is reading that there is no power getting to the ignition coil. I am completly lost with this!!! Any help is better then no help!! I have the owners manual and the wiring diagrams if needed. Thanks,
Kazuma jaguar 500:thanks:
Zrock Feb 10, 2016 09:51 AM
Well if it ran until you were pulling the wires back to the battery box then their lies your problem. You have probably broke a main power wire to computer or jiggled the fuse loose. Start following your power wires. One will go to starter and one will go to computer or fuse box.
© 2026 MH Sub I, LLC dba Internet Brands
