Tao tao 135D won't start.
Hi all. We've had this quad for a little over a year now. It worked fine for two months, then one day it just wouldn't start again. I've been futzing with it for a year now and am coming to the experts for help.
It is an electric start. It does crank over but does not start. It is getting fuel. It is not getting spark. The rear kill switch has been unplugged (open, not grounded), the left hand kill switch is in the on position. The brake switches are working properly and the brakes are on while trying to start. The remote start/kill box has been unplugged (it won't start with it plugged in either). I have replaced the wiring harness, CDI (5 pin type), rectifier, and ignition coil with no luck. I've even tried different combinations of the original items and newer items. It has fresh gas, which won't make much of a difference with no spark but I thought I'd mention it. I'm about ready to just give this thing away at this point. I'm pretty mechanical and have worked on vintage cars for a long time (not professionally) but this has me stumped. HELP!!!! LynnEdwards, are you out there? |
On some bikes the rear kill wires have to be connected together for the bike to run. Also some need a wire between two of the pins if the remote start/kill is removed. However, assuming you have AC ignition, the kill wire from the CDI can be disconnected to by-pass all that lot. One problem though, some bikes only spark with the kill wire not earthed, some only run with the wire earthed. On most CDIs it is the black wire with white tracer.
You might find this old thread helpful:
https://atvconnection.com/forums/1-e...-no-start.html |
pull your wire about of the cdi like stated above. This will bypass all safety items. Also this may sound funny but try unplugging the rear tail light. I have had it where the wire or light was shorting out causing no spark.
It was the stator.
Thanks for all the tips guys. Sorry for the late response, but Thanksgiving and all. Well it turned out to be the stator. I really hadn't expected a brand new stator to go out, but then again I hadn't expected a brand new atv to just quit working, even if it was Chinese. Anyway, the kids will be excited to ride it again since it's been over a year since it broke. And just in time for Christmas too! Happy Holidays everyone!
one thing to watch on these imports as they don't seem to be washing safe... seems like they are fine bombing through puddles but as soon as you wash em off and try to start its always been trouble im my experience. i always let em sit for the afternoon before trying to start after washing. i have blown a few electrical components after washing on these things
Thanks for the heads up.
| All times are GMT -5. The time now is 05:02 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
