ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   1) Engine problems.. (https://atvconnection.com/forums/1-engine-problems/)
-   -   Tao Tao 125 ATV won't start with starter button (https://atvconnection.com/forums/1-engine-problems/377083-tao-tao-125-atv-wont-start-starter-button.html)
brandyp Sep 26, 2018 07:55 AM
New Tao Tao 125 fourhwheeler will not start when the starter button is pushed. When we put a screwdriver to the solenoid it cranks right up. We have replaced the carberator, ignition switch, choke cable and the solenoid. We even took off the starter button/kill switch and disconnected and reconnected the wires. The brake light is not coming on either. We are contemplating replacing the starter button. Need advice.
Zrock Sep 26, 2018 09:18 AM
i would almost bet one of your safteys is not working if the brake light is not coming on. On ours the one for the foot brake quit working the 2nd ride. I re-adjusted and worked for a few more rides before failing again. The one on the hand brake always worked good just seems to take more force to get it to activate
brandyp Sep 26, 2018 11:40 AM
The brake light is not coming on when either or both brakes are pushed. How do I check to see if the wires have a good connection? I keep reading that a non working brake light is a safety feature and won't allow the atv to start. It quit working at one time and we ended up replacing some other part that wasn't connected to the brake light and now it is not coming on again when I turn the key on but the neutral light does come on.
carsonh Sep 27, 2018 10:00 PM
It may be the brake safety switch. If you can take that apart you may find a faulty connection. Dont think its a starter button problem.
good luck
© 2026 MH Sub I, LLC dba Internet Brands
