107cc China quad spark fuel little compression
Old Apr 10, 2020 | 09:39 PM
sanchezjesusisawesome@gmail.com's Avatar
Default 107cc China quad spark fuel little compression
So I’m new to the forum looking for help I have basic knowledge as I am an auto mechanic but my China quad 107cc unsure of the brand will not start has spark clean carb clean fuel but it spits it out from the filter when trying to start the timing marks all line up and the valves are adjusted does anyone think it could be the timing or a head gasket I want to be sure before taking the engine apart
Old Apr 17, 2020 | 07:55 PM
Adamaustin79's Avatar
AdamAustin
Default How’s the compression?
Compression is usually over 100 on the 110cc. The head gasket may be blown. They sometimes leak in the area with the channel that leads back to the engine case so it ends up pressurizing the engine case and not causing oil to leak on the outside of the head. I’ve also had the idle jet in the carburetor be clogged a couple times. The hole is so small it takes almost nothing to clog.
micademas
Honda Side by Sides
Jan 7, 2021 03:54 PM
Apr 10, 2020 11:19 PM
Eilrahc83
Jun 3, 2019 02:28 AM
~Ray~
1) Engine problems..
Jun 13, 2013 12:04 AM
macdog
Sep 21, 2006 09:30 AM
