Questions about internal engine parts for ata -d 250
So im looking to know the components on the left side of the engine case. First how many teeth should be on the starter motor? And with how many teeth on idler and/or reduction gear should be joined with it in order to create proper spin?. Right now im looking at a 9 tooth starter and an 18/62 and 14/16 gear. Reason i ask is i see a few different parts associated with this engine. 167fmm/cg200 i d k what the hell it is haha. I see an 11 tooth starter and not nessisarily paired with a 17t reduction/idler. Id like to know if i have the correct components and corresponding peices to create the proper members to get this thing to start. Also mayb the starter clutch sprag thing has to be thrown in there 2. One more thing i cant seem to answer is which direction the starter motor needs to spin.
thanks in advance
thanks in advance
