Qg213a wont start
Old Jan 3, 2023 | 08:23 AM
Casadilla's Avatar
Default Qg213a wont start
Alright I’ve tried everything this bike seems to not wanna start. It’s getting spark fuel and air
it pops when the starter is enguaged and dies dwn and struggles when given more gas but never actually turns over. I’ve treud and tried a lot it just stopped working one day
things I’ve tried
starter fluid
new cdi
new carb
timing
adjusted valves
cleaned sprrk plug
things I’ve replaced
head
cylinder wall(upgrade)
piston
starter
battery
air filter
ignition coil
spark plug
brand new wiring harness
note: this is a fully automatic with no kick start
Old Jan 4, 2023 | 03:32 AM
Check the TDC mark on the flywheel is at top dead centre by the piston. Check compression is over 90 psi. If both are OK I am at a loss, as you have checked and/or changed everything else.
nichopw
Mar 28, 2021 12:57 PM
Jörgen Raja
1) Engine problems..
Sep 23, 2019 03:04 PM
madmax1398
8
Apr 21, 2013 06:25 PM
2knarf
Feb 11, 2010 10:46 AM
