ATV 200 cc mods
Old Feb 16, 2015 | 11:37 AM
Speed_LTU's Avatar
Default ATV 200 cc mods
Hi, Is exist any china ATV quad engine mods, like 4 valves cylinder head or something similar? Or shop with performance parts for china quad?
Old Feb 17, 2015 | 03:31 AM
There are firms that do big bore kits for the common engines like the GY6 etc, but 200cc is bigger than the normal "Honda clones" so your engine is likely to be made in small numbers and not worth making special parts for. Also frame parts and shocks are often not up to the performance of the standard engine so more power could lead to trouble.
Old Feb 17, 2015 | 08:00 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Ive never found any hop up item's for the 200cc or the 250 cc engines.. The first thing Id do is eliminate the air box if it has one, Install a Uni Pod filter and see if you can find a aftermarket universal muffler for it if yours isnt a straight thru design.. The other thing to do to all Chinese quads is to go to larger jets... These engines are gasping for fuel at all rpm ranges and getting the engine more fuel will help...
If your over 4000' in elevation the stock jetting should be fine.. under that and your jetted lean..
Old Feb 18, 2015 | 10:07 AM
Speed_LTU's Avatar
Anyway thanks for advises, but where you guys can suggest to buy custom parts(carbs, mufflers, RCDI and more) is any specialized shop which sell these items? Thanks.
Old Feb 26, 2015 | 08:25 PM
whygostockcom's Avatar
Banned
Whygostock.com has upgraded EBC Clutches, Uni Pod air filters, better bearings and tie rods, twist throttle conversions, graphics kits, and many other items
Customer Service #1
May 15, 2020 08:46 AM
Sep 23, 2015 06:23 AM
PrairieDog126
Sep 16, 2015 01:33 PM
1ArmBandit
Sep 8, 2015 08:59 PM
JakeXBL
Sep 5, 2015 01:08 PM
