Bad vibration and noise at high RPM
Old May 20, 2018 | 07:34 PM
jhenry330's Avatar
Default Bad vibration and noise at high RPM
Any ideas what the cause of this is? Makes the same vibration/noise in neutral or in gear...
Thanks in advance!
-jeff
Old May 21, 2018 | 03:06 AM
Sounds a bit like a loose timing chain. You didn't take the wrong plug out under the engine and loose the long spring an plunger did you?
deuceswild
Jan 11, 2010 09:29 PM
RacinJason
Feb 26, 2003 09:52 PM
Hightower
Jan 23, 2003 05:58 PM
Buckfever
Apr 29, 2001 05:29 PM
thomasak17
Aug 25, 2000 11:08 AM
