blaster is it good in the woods
Old May 2, 2000 | 08:21 PM
thomas's Avatar
i want to get a blaster, i am not sure about the oil injector if it would fail. but anyways do you think they are good in the woods. do they ride nicly in the woods. do you foul plugs alot or not.
Old May 2, 2000 | 09:29 PM
94DGblaster's Avatar
They are decent. There are better, like a Trailblazer(i found it a lot easier to ride my Trailblazer on trails)
They will fly down hills and trails, but it's hard to take stuff slowly.
Ground clearance is low.
Hill climbs with them are a blast, and so is speeding down open trails and nailing it into turns.
I am going to get longer A-Arms and a longer swingarms(+4) too help keep the front end down when climbing.
Old May 2, 2000 | 11:39 PM
b(250rman)'s Avatar
blaster in the woods that is like peanut butter to jelly I had a moded 1998 blaster rode it in the woods every day it has great handloing skills. also 94 DG blaster turn your front wheels inside out and that will make your bike wider. I did it to mine and worked great. on my 250r i out wider off set wheels.
86 trx250r wiseco +0.20 piston,boyeson reeds,FMF gold series fatty pipe,power coire 2 silencer,DG alloy series nerfs,Motion pro twist throttle,pro design kill switch,20/11/9 6 ply razr's on ITP .190 wheels,18/11/8 holeshot mx's on mitchell .190 wheels 21/7/10 holeshots on wide off set ITP .190 wheels,nac's casesaver,uni filter,future mods includde works triple rate front shocks with res's,revalved stock rear shock,leagers +2 +1 inch a-arms and DG front bumper.
Old May 3, 2000 | 04:24 AM
YamahaRules's Avatar
Blaster is AWESOME!
Old May 3, 2000 | 09:15 AM
BLASTER_14's Avatar
the blaster is great in woods as long as you show it whos boss got to throw it around a little
Old May 7, 2000 | 07:52 PM
roper0002's Avatar
They are great in the wood's .. Only problem i have is ground clearnce .. You will need a bigger tire and a different tread but other wise you can go just about anywhere you want to go..
I have a 98' Blaster with 22/12.5/9 with 190" doulas rim's, back racks , dry box ,skid plates , and fogg light's , ..
Geat a yamaha there the only way to go ..
Frisky2050
Apr 9, 2020 11:19 AM
coldnorthpol
Jul 14, 2015 11:22 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
Technical and How-To Articles
Jul 2, 2015 01:34 AM
