Sputters When I Wheelie
My DS when I pop a wheelie right out of first hesistates and then acts like it's not revved up enough. I also have troubles going up hills. I dropped back from 3rd to 2nd clip and it helped but still bogs when wheeling. The valves are fine (.005). The floats seem ok. I have noticed some gas coming out by the radiator every once in a while. It must be an overflow from the gas tank. The threads mentioned a similar problem but there never was a solution. Help would be greatly appreciated. I also notice a hesitation when I nail the throttle from a dead stop. After the hesitation it runs great right to red line. Main jet is a DYNO Jet 185 with the above clip setting. UNI filter in the air box.
I would get some carb cleaner and go thru every circuit and flush it out, particularly the idle circuit and pilot you may have a bit of varnish or debris that is restricting flow from idle to 1/4 or where ever. Something isn't quite right , those stock carbs are usually very reliable and quite responsive. Once it's running correctly you should be able to just blip the the throttle( to about 1/4) and have it stand straight up on the street.
Bogging is usually a float bowl issue. Try lowering the clip on the needle one or two more positions and see if that helps. Is you bike still under warranty?
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
