Oil Fitting Screen
Old May 3, 2000 | 02:30 PM
MagnumMudMan's Avatar
I was looking a my wife's 2000 Trail Boss owners manual and it says you should remove the oil fitting on the oil tank and clean the screen on the fitting. I checked in my owners manual on my 1998 Magnum 425 and it does not mention anything about the screen. My question is before I tear apart the fitting, does the 1998 425 have the screen fitting? If yes, what type of sealant should I use when reinstalling the fitting?
Old May 5, 2000 | 12:42 AM
Deej's Avatar
MagnumMudMan,
My understanding is that all Polaris 4 strokes using the dry sump and external tank have the screen in the lower fitting of the tank. The various years of Sportsman that I have worked on do. I clean the threads on the fitting well and coat them with standard pipe joint compound. I do not use teflon tape but some do. The Polaris service manual calls for "Loctite PST 505 or equivalent pipe thread sealant or PTFE sealant tape". Just about any pipe thread compound will do just fine. The fitting and tank have a "tapered piep thread" that, by nature, are soemwhat self sealing. The compound is mostly a precaution, but it is required.
It is a large fitting requiring a large wrench. Be careful tightening it. It is very easy to over do it. Steel fitting in aluminum tank will strip the threads out pretty quick.
DJ
Old May 17, 2000 | 01:36 PM
walexa's Avatar
Deej,
When cleaning the screen, do you ever find anything in it. I mean, is it pretty necessary to check it at every oil change. My bike (sp500) has about 350 miles on it. The oil has been changed about 4 times. How often would you clean/check the screen. Thanks.
Old May 17, 2000 | 01:45 PM
sixty9cobra's Avatar
My son has a 2000 TB 325 It does not have an external oil tank. It is wet sump thats why it hold more oil than My sportsman I think? Will take a closer look tonight. Its time for its first oil change anyway Maybe I will do it tonight.
Old May 17, 2000 | 02:11 PM
walexa
Based on the advice from Deej, (thanks Deej), I removed the oil fitting and cleaned the screen on the fitting. The only thing I found was some fiberous material on the fitting. It was not much and probably did not impede oil flow at all. I had changed the oil three times previously without removing the fitting. In the future, I will probably remove the fitting every other oil change, depending on the looks of the oil coming out of the tank. Hope this helps.
Old May 17, 2000 | 11:41 PM
Deej's Avatar
I would agree with MagnumMudMan. All I have found in the screen is the fibreous material. I will certainly check the screen every second or third oil change, but no more.
DJ
Old May 18, 2000 | 12:54 AM
Hugh's Avatar
I cleaned mine on the first oil change.....20hr and I too had the mysterious fiber material on mine as well.
Will probably check every other oil change too.
Hugh
EIF
Apr 20, 2017 07:15 PM
tysonbully
Sep 28, 2015 02:30 AM
2many2ride
Sep 27, 2015 04:35 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
