octane booster?!?
Old May 17, 2003 | 04:21 PM
miniblaster's Avatar
Default octane booster?!?
a bunch of my local freinds run octane booster, and i was wondering if this is good or bad. with my mods my banshee is running great, and finally jetted right, so does octane booster really help or not?
mini
Old May 17, 2003 | 05:51 PM
scramblered's Avatar
drop it in some KLOTZ octane booster,you won't regret it,it will actually run better if timing is retarded,it very help if you're not sure of the local gas station stuff,on a modded engine it will help to run cooler and give some extra hp with the timing properly set.
Old May 17, 2003 | 09:28 PM
danzo's Avatar
Actually, octane booster helps only if you are running compression high enough to warrant higher octane or if your timing is ADVANCED far enough. All octane does is resist detonation. You want to run the lowest octane possible to achieve the most power. If you don't you are actually preventing the engine from burning all the fuel, yes it does run cooler and safer, but less power. That is why some snowmobiles (Polaris) have a key to advance the timing when running higher octance fuel.
But in most instances, you can't tell by the seat of your pants that there is a difference.
Old May 18, 2003 | 11:33 AM
garyc660R's Avatar
Originally posted by: miniblaster
a bunch of my local friends run octane booster, and i was wondering if this is good or bad. with my mods my banshee is running great, and finally jetted right, so does octane booster really help or not?mini
It's good and bad. Octane booster and especially oxygenated boosters raise fuel requirements. Since you are jetted fine....I wouldn't use any booster. A veteran tuner can have trouble tuning oxygenated fuel....be VERY weery of this!!!!
Old May 18, 2003 | 10:38 PM
thanks guys
mini
Polaris-400
Aug 19, 2015 02:20 AM
BLC
Sep 22, 2000 05:13 PM
88trx310R
Aug 20, 2000 11:51 PM
AZBANSHEE1
Apr 18, 2000 11:26 PM
