How will this affect the 400EX?
Old May 26, 2003 | 09:47 PM
Coyotechaser's Avatar
Default How will this affect the 400EX?
Will the inrease in carburetor size affect the performance much? (35.5mm to 38mm)
Old May 26, 2003 | 09:52 PM
yellowexracer's Avatar
I think that it's only recommended with other mods but i'm not sure. I just took the choke out of mine today and if helps throttle response.
Old May 26, 2003 | 10:25 PM
The change from 35.5mm to 38mm is a factory change for the 2004 400EX model. Will the change help the performance much?
Old May 26, 2003 | 10:34 PM
I should help but i don't know by how much. Did you read this on the honda site?
Old May 26, 2003 | 10:48 PM
If you go under Hondamotorcycles.com, quads, sport quads, and then 400EX. It has the spec.'s for the 2003 and 2004 models under each year. The carb size is the only noticeable change.
Old May 27, 2003 | 10:54 AM
DSAPP's Avatar
wonder if they had to increased the carb size because they changed the cam, piston, and valves for more power???
that would be sweet! at least so it won't be beat by the Z's anymore... that's all they'd have to do
Old May 27, 2003 | 12:02 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
It is about time they started doing yearly upgrades on quads!! Look at the MX dirt bikes, they get tons of upgrades every year. The manufacturers just have not given us the respect that we deserve. And, Honda needs to stop being so timid about power if they are going to compete in the marketplace. Competition is good!!!
Old May 27, 2003 | 12:34 PM
Red Rider
What carb does the XR400 dirt bike have???????
Old May 27, 2003 | 12:56 PM
reconranger, The 03' XR400R has a 36mm piston-valve.
The 03'/04' CRF450R has a Keihin 40mm flat-slide.
Old May 28, 2003 | 12:18 AM
Visually the only thing that appears different from the 2003 400EX to the 2004 is the graphics. (very little change) The motor appears to be the same in the 2003 and 2004 pics.
