building banshee motor
Old May 27, 2003 | 01:30 AM
scrambansheeman's Avatar
Default building banshee motor
what engine setup would give me the most power on pump gas and still be a reliable engine for all day dune riding. probably will go through kt performance. i have an 00 banshee 19cc domes and toomey t5, boysen reeds.
Old May 28, 2003 | 12:29 AM
some of you have to have an oppinion on this. long rod, stroked, 400 powervalve cylinders????
Old May 29, 2003 | 09:01 AM
RoostKing's Avatar
I think a stroker or long rod is the way to go. I have a mild 420 stroker and LOVE IT! It has power everywhere, yes even bottom end, and screams on top. I can ride the dunes, or go trail riding. In fact I just did a 36 mile loop, just cruzin and the banshee performed flawlessly. I went with a 7 mm stroke, but a 4 mm is cheaper and should give nearly the same results..
RoostKing...
Old May 29, 2003 | 10:41 PM
SykoQuadRider's Avatar
Roost about how much would it cost and how much HP? Thanks man
Old May 31, 2003 | 02:25 PM
hwyTOhell1988's Avatar
if you have any stock motor parts left over and need some cash tell me... I am looking for any banshee parts i can find reallt so far I only have a swingarm but I am also looking for a frame
Old May 31, 2003 | 05:01 PM
roost? can you please tell me about how much price HP? thanks
Old Jun 1, 2003 | 11:49 PM
machwon's Avatar
In my opinion banshee motors can run awesome (mid 70's crank HP) with a set of pipes, all stock parts properly modded and ported. The crank would have to trued and welded too but all should be doable for less than a grand.
Old Jun 2, 2003 | 03:37 PM
Katos's Avatar
I have a 370 set up for dragging, but just finished another 370 for a friend, who rides everyday and is not one to wrench everyday. His is a 370 long rod from CT racing, and this things rips in most all throttle ranges. He is running 50/50 race fuel in it, and I would not go any leaner on this mix. CT does great work, just call Allen up and he will fix you right up.
KaTos
ReconBayou
Oct 31, 2022 05:37 PM
bmxatv10
Oct 14, 2022 06:23 PM
Clint Russell
Sep 25, 2015 03:20 PM
BYC
Sep 25, 2015 02:10 PM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
