Help. I need some low-end grunt for my 310r!!!
Old May 28, 2003 | 02:18 AM
Bartman's Avatar
Default Help. I need some low-end grunt for my 310r!!!
I have a 250r with a Pro-x 310 kit. I have a FmF fatty pipe and silencer and K&N filter. I do, have a 38mm carb coming. Should I put a reed spacer in and what type of reeds or reed system should I put in? I mainly need the low-end to mid range power. Mostly ride trails and occassional mx. Also, I am running 32:1 ration on fuel. is that too rich? Any help would be appreciated. thanks
Old May 28, 2003 | 02:39 AM
trx250Rob's Avatar
Get an esr trx-6 pipe, it is increadible. With your 310 it will pull like crazy, makes it feel almost four-stroke. As for the reed spacer, I hear it does little or nothing.
Also if you are looking for low-end power you shouldn't get a 38 carb, bigger carbs give you more top end at the expense of low end power. You should get a 36. A smaller front sprocket will help too.
EIF
Apr 20, 2017 07:15 PM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
Sassinm1
Sep 30, 2015 04:23 AM
Matt123
Sep 29, 2015 01:29 AM
2many2ride
Sep 27, 2015 04:35 AM
