best mod for the buck on v-force
Old Jun 3, 2003 | 12:50 AM
melbatoast56's Avatar
Default best mod for the buck on v-force
I just bought a v-force and i love it it is so fast well i was just wanting help on what the best mod for the money is. I would like to get the dual exhaust but i just dont know if it is worth the money or not. WOuld it be more worth it to just get a slip on. What is the best exhaust for the v-forceare there any other cheap mods that help. ANy info you can give me would help thanx.
Old Jun 3, 2003 | 09:43 PM
NorthwoodsRider's Avatar
You are wise to ask about which exhaust is worth it. I have read that some mods actually lower horsepower. Good luck.
Old Jun 3, 2003 | 09:53 PM
sportyroxx's Avatar
If i were you i would just wait for the all of the exhaust companies to make there pipes, that way you can see who makes the best and worst. I know that HMF makes a good dual and a slip on pipe. Yoshi is real close to the making there dual pipes and my bet is on them making the best ones. My first mod will be some better shocks, that will help you better than anything. Just search around and see who has the best. DMC makes some duals, thats the kind of pipe that Brock Parker uses in the GNCC utility unlimited class and hasnt lost yet.
Old Jun 3, 2003 | 11:47 PM
KevinM's Avatar
A $20 primary spring will give better stall at the bottom and more RPM's on top.
Old Jun 3, 2003 | 11:55 PM
PCDoc's Avatar
Hey Kevin, were you the one who is using a brown primary in your V? I took the red one out because it was just too abrupt on the engagement from a stop. Thanks.
Old Jun 4, 2003 | 12:08 AM
Force's Avatar
Best mod you can buy is called wait. Dont jump on these first mods that are out there, better will come.Time and research will produce better quality and power.
Old Jun 4, 2003 | 12:17 AM
KevinM's Avatar
That's true to a point, but I was getting pulled on top end by 3+ quadlengths by my brother's piped Banshee until I did a simple primary spring change. Now my front tires are equal with his rears for under $30. Polaris brown primary - $20, six 1" univents mounted on the airbox - $7. Picked up 2 quadlengths, half-hour install time.
Doc, you just can't go too radical with the springs on these things. The Polaris' engage gradually, but the 700's slam all at once making them unrideable if too much spring is used.
Quad Pics
Old Jun 4, 2003 | 12:27 AM
Force's Avatar
Kevin M- Cant beat that for $30.00. Im talking more about spending major cash. For $30.00 you cant go wrong. I spent that just on extra V- FORCE decals to put on. I just dont want to buy anything and then find out theres better out now .
Old Jun 4, 2003 | 02:10 AM
CAM650's Avatar
Hi Kevin-
I just got a V-Force tonight. I have a Prairie 650 and I'm new to sport quads. Please explain in detail the modification you are talking about. Where do you get the spring? Does it effect your bottom end power? What are univernts?
Thanks,
Chris
Old Jun 4, 2003 | 08:20 AM
NYVForce's Avatar
I bought the polaris plain spring I should have that today I did'nt like the polaris brown it did'nt engage till almost 3500 rpm it just seems like to much strain on the tranny, plus it was a pain to use reverse. I have the EPI red in now and that engages at 2800 rpm it's still a little high so I'll put in the brown spring and let you guys know how it is.
