i have a ? regarding 2003 eton viper 50
Old Jun 5, 2003 | 04:09 PM
kebo's Avatar
Default i have a ? regarding 2003 eton viper 50
actually i have 2 questions...first off, where is there rev limiter wire and what color is it? and 2, i just purchased this atv for my son and he hasnt ridden it but probably 1 hour total, and was riding yesterday and it just quit, and will not start back, just keep cranking, i have checked all connections that i can see and i just wondered if anyone could help....thanks in advance!
Old Jun 5, 2003 | 04:30 PM
VowellBoysRacing's Avatar
Can't help u with the limiter wire, aws I'm not familiar withthat model but as for not starting, please don't think I'm being arrogant or smartallecky but did you check to make sure the gas is on. Also if it has a kill button,( start/run switch ), on the handlebars make sure it is in the run position. Next there is a relay and fuse iether under the seat or behind the front plastic that just might be bad from the factory! OH! YEA!...if it has a walk behind tether kill switch make sure it is well seated.
Old Jun 5, 2003 | 04:41 PM
kebo's Avatar
yea i did check the gas, even switched it to reserve...all ok there..switch is in the "run" position..havent checked any relays with meter or anything, i will leave that to the dealership i guess....thanks anyway man!
Old Jun 8, 2003 | 07:43 PM
Ordie1's Avatar
Your limiter is on the throttle box.. It is a small screw with a nut around iton the forward side of the box. If you screw this in, It limits the amount of throttle you can use. You need to keep it in to at least half throttle for About 10 hrs riding time. (factory recommended breakin time) Make sure that the walk behind teather beneath the seat is seated. I know the 50's have them. I don't recall if they have the wrist teather is there. My son has the 90 and it doesn't. I don't think that the 50's have it. The only other option is that the run/stop selector is in the off position.
Old Jun 8, 2003 | 10:33 PM
kidsatvracing's Avatar
That's right all switches and tethers pluged in and on. If that doesn't work change the spark plug.
Jadester's Avatar
The limiter is the green wire that you see if you look behind the front screen of the quad. It comes out of a little black box and is approx. 5 inches long and then it goes back into the same box. Just cut it and cover up the ends. My sons quad (the exact same as yous) did the same thing by not running the day after I got it. I remembered seeing someone say that you have to take the gas line off (in front of the fuel petcock) and blow into it. When they make the gas tank, they drill out a hole for the hose and a small piece of plastic sometimes gets clogged up in the line. I did this and have not had a problem ever since.
We have had this quad for 2 months now and absolutely love it. No problems since the first little problem.
And believe me, we ar not the nicest people to it. It ROCKS for a 50cc through the woods.
Cutting the wire helps immensly. Hope this helps.
Old Jun 10, 2003 | 09:21 PM
mxmike's Avatar
I also have a 50 viper.I had the same things happen to mine.Plastic in the tank.The
walk behind tether cord was loose once.Also I cut the green wire on the cdi and ...Vroooooommmmmm lol.
One more tip I have done to mine.I fliped the front and rear rims to were the valve stems face to each other.In other words I fliped them around and now the offset is wider to the out side of the quad.It makes the bike about 3 1/2 inches wider and alot more stable.For the fronts you will have to drill a hole for a new valve stem on the other side of the rim and add a new valve stem.Pull the old ones out and flip them upside down so it will cler the brakes.
We have had ours for 6 months so far and its been treating us great.Most of its riding time is spent on mx tracks.
Old Jun 14, 2003 | 08:48 PM
CTR's Avatar
CTR
My daughter has a 2004 Eton Viper 50 and I can't seem to find the green rev limiter wire under the front grill. Only green wire I find is going to the low oil indicator light on the handlebars. Any help would be appreciated.
Old Jun 16, 2003 | 05:24 PM
Some of the plastic you may find could also be from a deteriorating fuel filter, I have seen some other units with the glue coming apart in the fuel filter and heading down to the carb.
Our 2004 Viper 90 did not seem to need the green wire snipped so I didn't even look for it, maybe your 2004 50cc doesn't have one. I'll be taking a closer look soon.
Old Jun 30, 2003 | 06:33 PM
pigpen's Avatar
I took your advice on flipping the wheels! I only did the backs last night, but it makes a big difference. I did
not get around to doing the fronts (more work). How did you cover the old valve stem hole for the fronts?
Just want to make sure I understand before I go drilling them out. Can you expand on this the front wheels?
