K&N, UNI, or Twin Air - Which One?
Old Jun 6, 2003 | 02:49 PM
polarigirl's Avatar
Default K&N, UNI, or Twin Air - Which One?
Which air filter do you run or think is the best? I have a K&N filter now, but I don't like the way it filters. Do the others do a better job of filtering while still allowing good air flow.
Old Jun 6, 2003 | 03:12 PM
scramblered's Avatar
kick *** air filter,i've run several on mine scrammy and they allow a lot more air through the engine,i ran them with no pre-filter and they lasted
longer than k&n.
Old Jun 6, 2003 | 05:14 PM
polarigirl's Avatar
Kick *** air filter??????????? huh???????
Old Jun 6, 2003 | 05:17 PM
BigBadScrambler's Avatar
I like my K&N. As long as you clean it when needed it does great. Make sure you run a prefilter. If will keep a lot more crap and water out and make it last a lot longer
Old Jun 6, 2003 | 05:25 PM
CED's Avatar
CED
Both are good filters,if cared for the right way.The K&N will definitely flow more air.But for trapping dirt and sand you can't beat a properly oiled foam filter.The thing about the foam filters is no need for a pre filter or outerwears.I personally ran K&N for years ,but recently switched to foam after doing my own testing on both filters.Hope this helps.
Old Jun 6, 2003 | 05:54 PM
NCScrambler's Avatar
I had probs with the K&N and have used both Twin Air and Uni since, I feel they both flow about the same and filter much better than the K&N ever did. I think with either one, you will be satisfied.
Old Jun 6, 2003 | 06:01 PM
ProXPredator's Avatar
I run the K&N, but I can't say it's better than any others, because I haven't run any others. I have had no problems running the K&N in my Predator or my Scrambler, does a great job and clean out great.
Old Jun 6, 2003 | 07:39 PM
ftwflh's Avatar
I have both and for the price the UNI is winner and I think the both filter good as long as you keep them clean
Old Jun 6, 2003 | 09:19 PM
yeah,kick *** air filter,they're snowmobiles filter,fit 36 to 46 mm carb
20% more power than comparable filters.
i run them during the hot summer days in my scram and it work
best.
Old Jun 7, 2003 | 12:36 AM
mojave300ex's Avatar
I prefer UNI over K&N after testing both on my 300ex, the K&N leaves dirt around the intake area... the UNI is always clean, you can't tell a difference in power of your machine. So why K&N if UNI filters better and cost half as much???
