Grizzly Belt Drive Help
Old Jun 9, 2003 | 10:12 AM
shane8813's Avatar
Default Grizzly Belt Drive Help
i have had my 2001 grizzly for about 2 1/2 years and i only have about 330 miles on it.i started it up to let it warm and after a few minutes i started hearing some strange sounds from the transmission area.it sounds like it's the belt drive,can anyone tell me if this is a project i could tackle myself or should i pay those sky high labor prices.thanks for your help
Old Jun 9, 2003 | 11:17 PM
Vakero's Avatar
If it is the V-belt then it is an easy job to fix if you possess limited mechanical knowledge/ skill. The problem is that if it has been over 2 years since you have owned the atv you should regrease the primary and secondary sheave while you are there. Unless you are handy with a wrench you may want to get help or take it to be repaired. It will require special tools and a service manual to do the job. Remember to use a torque wrench on all bolts if you do the job yourself.
Cummins Driver
Sep 11, 2019 01:22 PM
merryman
Sep 6, 2015 10:20 AM
toonces
Jul 31, 2015 09:27 AM
Jul 28, 2015 12:12 PM
trouttracker
Jul 20, 2015 11:54 AM
