What should I do?
Old Jun 12, 2003 | 11:47 PM
dirtripper1's Avatar
Default What should I do?
hey,
what should i get a pipe or a clutch kit. I dont need much more speed i just want a little more take off power like so much i could pretty much pop a wheelie right off. I dont have enough money right now to get both the clutch kit and the pipe so which would be better to get?
thanx a ton for your help
dirtripper1
Old Jun 13, 2003 | 12:27 AM
biggin's Avatar
As to which to get,I do not know which(alone) would help you wheelie better. When you do make up your mind and buy a clutch kit or pipe, be sure in the future to buy the other part from the same manufacturer.Later.
Old Jun 13, 2003 | 02:19 AM
RookWV's Avatar
I'd have to say the clutch kit but I'm not sure that alone will give you the power for a straight off wheelie, but the clutch will give you better take off.
Old Jun 13, 2003 | 07:49 AM
ftwflh's Avatar
If money is tight just change the primary clutch spring to a Polaris white spring.
Old Jun 13, 2003 | 08:15 AM
scootergptx's Avatar
Supersock
Hired Gun!
if you're only getting one at a time, get the clutch kit or spring first. you won't get all the performance from the pipe without the clutch kit.
Old Jun 13, 2003 | 04:18 PM
hotseatperformancefan's Avatar
i would say get the pipe first because when you buy the clutch kit they change certain parts of the kit to fit mods on your quad. I got a hsp pipe on mine and once the belt starts to catch it wheelies but i dont no what the clutch kit will do. So i would say get the pipe from hsp(hot seat performance) because it will give u a 7-8 hp increase and 5mph on topend.
