jetting for my ds
I have the mods I have listed and the weather here is hot as hell which seems to need less fuel. My ds run on the lean side every since I put the hmf pipe on. I have a dynjet kit with 190 main jet and needle in the 4th clip. It also runs on the hot side. thought it run like a bat outta you know. Just wondering if I should go up on the main and move the needle clip down some more. I live 260ft above sea level.
didn't i see you bought the hmf? i'd call them when i talked to them they had jetting for there pipe. we have the woods pipe on my wifes and run 170 main 4 clip and it works well. but then again at a 140 she should do well.
I have similar mods to you(except slide spring mod and CDI) and I gotta tell you that my ds ran lean at idle so I jumped it up to a 50 pilot(had trouble finding 47.5 pilot, if you find one tell me where to get one). I suggest you try it also, then three turns out with the dyno jet kit. 195 and third clip position is good for our mods
