would i come close or win ?
Old Jun 17, 2003 | 09:20 PM
dirtripper1's Avatar
Default would i come close or win ?
who do u think would win if i HPD piped and put on a clutch kit and raced a 350 yamaha warrior '98 i think its only mods are a high flow intake?
Old Jun 17, 2003 | 09:26 PM
scrambler123's Avatar
you would probably win but not by much i had a piped and clutched tb and raced a piped and filtered warrior and lost by a little bit.
Old Jun 17, 2003 | 09:34 PM
ScRaMbLeRiZeD's Avatar
You might be able to beat a warrior with a pipe not sure though.
Old Jun 17, 2003 | 09:45 PM
2manytoys's Avatar
When I first got my TB I would lose against a blaster and lt230 all the time. I then put on a pipe and clutch kit and I would walk away from the blaster. A warrior would get me in 5th gear on a long drag. But once I got the motor ported and a bigger carb I am able to kill a warrior,blaster,300ex and able to keep up with a 400 ex till about 5th gear and can hang with a 400 scrambler. So with the pipe and clutch kit you should be able to stay with a warrior if not beat it. Off the line you will easily get it but he has higher gear ratio to shift through. This is with the HPD pipe. I dont think any other pipe other than RCR will give the same performance on a TB.
EIF
Apr 20, 2017 07:15 PM
2many2ride
Sep 27, 2015 04:35 AM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
black_thunder
Sep 6, 2015 04:41 PM
