EPI Clutch Weights
Old Jun 18, 2003 | 04:49 PM
NovaKaw650's Avatar
Default EPI Clutch Weights
Has anyone tried the new clutch weights (or the entire kit) yet. I talked to EPI today - they had some good information. If you run stock sized tires and do sport style riding, they recommended the 56 gram weights, black secondary spring and either the stock primary or their new pink primary spring. The pink spring is nearly zero stall like the stocker but has progressively more tension than the stock. The pink spring won't be ready for a few weeks yet.
They said the weights will make a difference that you can both feel AND measure.
Let us know your results if you have tried them.
Old Jun 18, 2003 | 05:10 PM
SHOTGUN's Avatar
Scott;
What was the cost of the kit,
Old Jun 18, 2003 | 05:24 PM
NovaKaw650's Avatar
The weights alone are $125 (ouch!) and the Pro kit (two springs and the weights) is $199.
Old Jun 18, 2003 | 05:35 PM
SHOTGUN's Avatar
I looked into making some adjustable weights like we had talked on a post, I couldn't find weights that were cut on one side only. Most weights are cut on both sides, this doesn't allow room for the head of the bolt you would use when you added weight.
I have heard that Polaris weights, with the pin hole drilled out more, will work. I think 4 would be in the $50.00 range.
Old Jun 18, 2003 | 05:39 PM
DirtyWhiteBoy's Avatar
So, that setup should shift the power band lower? How heavy are the stock weights; did you notice?
With the pink spring I would guess you would lose some top end, no?
Might be a great setup for pulls.
Old Jun 18, 2003 | 05:58 PM
SHOTGUN's Avatar
I forget what my stock weights were, I think 60kg, the lighter weights, if in fact they are lighter than stock, will give you more RPM's.
For pulling I'm using 46 kg weights, to get my RPM's at 6500
Shouldn't lose any top end with pink spring, maybe gain a little. Maybe.
Old Jun 18, 2003 | 06:41 PM
Wolley's Avatar
I haven't called EPI but I have been wondering just exactly what the 650 clutch kit contains.
So let me get this straight. I can buy the weights and two springs separately for 171$ or I can buy the kit which contains the weights and two springs for 199. Uhhhhhh? I saw it marked this way in the catalog also and figured there was either something else in the kit or it was misprint.
buddieboy
Dec 9, 2016 05:50 PM
Robinhood
Dec 26, 2015 10:28 AM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
