I luv carbuerators! Yea right.......
Old Jun 19, 2003 | 04:34 PM
ALIENraptor's Avatar
Default I luv carbuerators! Yea right.......
Well I put in the 25 pilots it seems to run ok no hestation but theres still black smoke coming out of the exhast (not much though) and when i rev it to wot in nuetral a **** load of black smoke pours out? What is this? One of my air fuel mix is at 2 and the other alittle more than 3?
Old Jun 19, 2003 | 04:43 PM
O and btw it does'nt do this in gear?! I guess in neutral i hit the rev limiter? C'mon, somebody?!
Old Jun 19, 2003 | 04:56 PM
CTRaptor's Avatar
Is your air filter clean? Black smoke is usually caused by too much fuel and little air flow.
Old Jun 19, 2003 | 05:07 PM
yes, my air filter is clean. Any one else? I this a float prob?
Old Jun 19, 2003 | 06:29 PM
runs perfectno worrys! Im so happy with it. WOw i cant believe leaning out the pilots would do so much! Next week Im gonna check my floats and tell u how it goes this weekend!
Old Jun 19, 2003 | 09:00 PM
wshrdskin's Avatar
You might have leaking valve guides. Oil getting into the combustion chamber.
Old Jun 19, 2003 | 09:09 PM
Its not blue smoke, its black. Could it be my a/f screws are too rich?!
Old Jun 19, 2003 | 09:20 PM
RacinJason's Avatar
If anything I'd guess that you are running a little lean with those jets(pilot)
Is the smoke on accel or decel?
Does it puiff out in a burst or flow steadily?
Old Jun 19, 2003 | 09:26 PM
Its smoke on deacceleration when im reving it in nuetral and only nuetral like i rev it past a certain rpm's and it starts to flow steadily!
Old Jun 20, 2003 | 05:18 PM
RacinJason's Avatar
What main jets and needle position are you running?
