Rejetting Procedure??? 400ex
Old Jun 19, 2003 | 11:57 PM
RideAllDay's Avatar
Default Rejetting Procedure??? 400ex
My question is I have 03 400ex with white bros. pipe, Uni air cleaner, no lid, and ready to re-jet i have purchased Dyno-jet kit, do i have to follow manual and remove front plastic and gas tank and remove the carb to do this or is there a simple way to do this, My dealer wants 150.00 to rejet, that seems a little high to me, I do have some mechanical skills,i would say above average, Any help would be appeciated,Thanks Guys!![img]i/expressions/face-icon-small-confused.gif[/img]
Old Jun 20, 2003 | 12:03 AM
400ex2003JPC's Avatar
Im attepting the same thing and I have the same mods as you basicly and a 2003 400ex...i just finished rejetting tonite and it took me about 2 1/2 hours..its kinda hard if you never done it before.....as pushingthelimit says "you'll get frustrated and want to throw sh**"
Old Jun 20, 2003 | 12:04 AM
TractorPacker's Avatar
Do you have a balloon?
If you are changing just the main jet you can loosen both clamps,twist the carb and remove the little center cap on the carb bowl. Inside that little hole is the main jet and it can be changed. If you are doing the pilot or needle you'll be better off pulling the carb out. That would be the plastic and gas tank,but not to bad of a job.
Old Jun 20, 2003 | 12:32 AM
RideAllDay's Avatar
Thanks guys i figured the pilot and needle would be a stress tester, i am also wondering what spark plug to run DPR8Z OR DPR9Z ? WHICH RUNS COOLER? Thanks again!!
Old Jun 20, 2003 | 05:20 AM
cals400ex's Avatar
dpr9z is the colder plug. however, it may be to cold for your engine mods or the temp outside. its worth a shot though. i run them without any problems. sometimes they make the bike harder to start though.
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
