Do tractor attachements REALLY work?
Old Jun 21, 2003 | 05:59 PM
Twaaang's Avatar
Default Do tractor attachements REALLY work?
Does anyone have actual experience with the various tractor attachments like a backhoe, dump bucket, etc? I know that we can plow snow and push dirt around. But a forklift???? I'd buy them in the long run but maybe an actual tractor or forklift would be better. Don't need anything for commercial use, just around the home in the mountains. Digging small footings, removing stumps, building fences, etc. Also what size of ATV is most practical for these applications.
Don
Old Jun 25, 2003 | 07:06 PM
ElectricShift's Avatar
I plow with my grizzly.
Old Jun 25, 2003 | 10:31 PM
Lightman's Avatar
I'm really interested in those pull behind atv lawn mowers, such as the models from acre-ease, or swisher. They hook up to the trailer hitch and usually have around a 60" cutting area. Seems like it would be fun to pull around the yard on the prairie =]
Old Jun 25, 2003 | 11:00 PM
well, those are good for cutting....but when i used one it wasnt as fun as a thought it would be, i was thinking ''cut grass at 30mph'' but you have to stay under about 5mph or the mower begins to bounce, shake, and rattle.
Old Jun 25, 2003 | 11:42 PM
Lightman's Avatar
which model did you try? I'm very curious about the experience, because nobody seems to have tried those pull behind mowers. Do they deliver a nice cut? I've heard 8-12mph you can pull with the higher hp models....?
Old Jun 26, 2003 | 12:10 AM
I pulled a snapper off-set that i rented from sun-belt
Old Jun 26, 2003 | 02:23 AM
swingset's Avatar
I just bought a 44" Swisher Pull behind for my Rubicon. It has a 10.5hp Briggs/Stratton. Cost $799 at TSC (on sale right now).
Here's my thoughts:
First, mine is the cheapest one there is pretty much, so it's a "Get off the bike to start/stop" kinda thing, but I don't mind that.
It will cut at 6mph, but not much more than that...or the cut is really uneven.
It's offsetable, so you can have it cut to the side somewhat so you are mowing a path, you don't have to drive through what you're cutting. If you're doing paths, this is great.
Although mine is a "finish" mower, it will cut pretty tall grass in 2 passes if you raise the deck first time through.
On a typical yard, it's pretty much useless unless you have zero obstacles. Trees and tight turns render it utterly useless. Get a cheap lawn cart or pull something behind your ATV and practice in your yard before you buy one, and you'll see what I mean. I bought mine solely for maintaining a trail, and in that capacity it's superb, but I wouldn't consider it for a yard with trees or tight turns. For $800 used, you can buy a lawn mower that will do a much better job on a small yard.
I also would suggest one that does NOT side-discharge. I have a friend with one, and any tall grass clogs the discharge port, and if he's doing paths like I do, he has to always "edge" with the opposite side to prevent clogging. Mine is a rear-discharge, and there's no problem using it anywhere so far.
Old Jun 26, 2003 | 01:58 PM
Well, actually.....when you pull the mower off to the side, that is for if you are pulling it behind a riding lawn mower, that way you can pull off to the side and cut a huge path, The mower that i used was more industrial, it was pretty much a brush mower and i used it to cut the edges of my property where sapplings had grown up.
Old Jun 26, 2003 | 10:40 PM
JohnO's Avatar
I bought the 44" swisher a couple of months ago. It's handy to a degree, but is definitely no substitute for a lawnmower.
Good: it's very difficult to ground out - will roll over sharp rises in the ground and maintain perfect cut height. Wheel axles are right in line with the blade axles, so if the wheels clear it, the blades will. Doesn't bog down in heavy grass. Can offset to one side and cut under bushes without driving through the bush.
Not so good: It won't turn any better than a quad, which is to say not very well. The quad tends to mash the grass down so that it doesn't all get cut. A bit of a pain to raise and lower the deck. While you can tow it behind a quad, it has no better ground clearance than a regular lawnmower, so towing it through the rough stuff is difficult. And it's very noisy. Really, if they just had a quick way to raise the deck way up for transport, I'd be happy.
In general, a quad is not a good substitute for a tractor. It isn't designed to be run at slow constant speeds - no deadman's throttle. No power takeoff, and just isn't built to carry that sort of equipment on a regular basis.
On the other hand, I have been looking at the dump bucket Swisher sells. That could be handy.
Old Jun 28, 2003 | 06:05 PM
Lightman's Avatar
Would you guys have been happier with the 60" model? It's not much more money, and has around a 13hp engine.... I just figure if my walk behind mower is a 22" cut, a 44" swisher really would only cut the time in half, if I could be as efficient(doubtful).... Anyway, the 60" seems like it would really make things a lot quicker. My yard has a lot of straight back and forth cuts without too many trees/obstacles. How do you guys find the quality of the cut? Does it look nice, like you used a mower?
