fuel octane question.
Old Jun 24, 2003 | 10:54 AM
SANDMAN430's Avatar
Default fuel octane question.
i'm about to go 13-1 on the piston and i hear to run 110 octane. the guys at the snowmoblie shop say the higher the octane the slower the burn, they told me to pour a little on the ground of each and throw a match on and i would see the difference. since a 11.5 will run on 92, my question is why such a big jump for the 13-1 would 100 work or is it just trail and error method?
Old Jun 24, 2003 | 12:43 PM
BigWaynester's Avatar
I run 100 octane unleaded with 12.5 piston, runs great.
Old Jun 24, 2003 | 01:29 PM
ANNIHILATER's Avatar
No Mercy Racing! Got NOS?
i would look on VPracing website and see what your compression calls for, i run straight c-14 for motors 13:1 or over, and yes it is true if you have too high of octane it sometimes works against you... the burn rate is what you want to get dialed in..i would try different types of fuel in a drag race running the same opponent and see what gives you the best results without knocking... usually too high of octane will make it rich on top, losing power if not burning right. every motor combo likes to run different with different fuel, also depending on outside air temp, and air density..
bigred20653
Oct 2, 2015 10:05 AM
PrairieDog126
Sep 12, 2015 06:53 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Bigtwin700
Sep 9, 2015 09:32 AM
Elkaholic
Sep 6, 2015 02:44 PM
