Plug fouling
Old Jun 25, 2003 | 03:30 PM
Uinthas's Avatar
Default Plug fouling
My Boss has a 92 Polaris 2 stroke 350.. He generally has to replace the plugs every 8 hours of riding because the plugs foul out. Pulled the carb & the main jet is a #30 & he rides around 8000 ft.. is this jet to big?? Any other thing that needs to be looked at??
Old Jun 25, 2003 | 04:05 PM
AgressiveRider's Avatar
Look at his fouled plugs. Are they black and oily or white?
Old Jun 25, 2003 | 05:45 PM
Uinthas's Avatar
yea, black & oily...
Old Jun 25, 2003 | 05:53 PM
NCScrambler's Avatar
What main jet is he running?? The factory calls for a #200 at that altitude he should be running around a #180 to a #185. Since it is a #30 pilot, he could probably do ok with a #25, but try turning the airscrew out first, (ccw) and see if that helps, if you have to go beyond 2.5 turns out from a light seat, then yes he needs to go to a #25. Also, if he is running the stock clutch set-up, he could gain some performance by dropping the weight size down one to keep the RPM's up at the high altitude. I would also recommend checking the oil pump settings and make sure the marks are in alignment and that the choke cable is adjusted properly.
Old Jun 27, 2003 | 01:14 AM
SHOEFITS's Avatar
A COUPLE IDEAS. HAVE YOU REMOVED PLUGS AND PERGED THE EXHAUST? MUD IN END CAP? OIL PUMP ADJ.PROPERLY?
Old Jun 27, 2003 | 01:19 AM
SHOEFITS's Avatar
ONE NICE THING ABOUT THE OLD 350L MOTORS IS YOU CAN BORE THEM TO 400CC WHEN WORE OUT. JUST CHANGE MAIN JET AND YOU HAVE A SCRAMBLER MOTOR
Old Jun 27, 2003 | 02:53 AM
Polarisdudee's Avatar
and you really dont need caps to say that. its like your yelling it.
Hankey Pankey
May 1, 2018 01:33 PM
Shainasmash
May 8, 2017 06:38 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
cornermike
Jul 30, 2015 06:37 AM
Captjay
Jul 23, 2015 12:33 PM
