Ok Guys Can U Help Me out
Old Jun 25, 2003 | 09:59 PM
steve89's Avatar
Default Ok Guys Can U Help Me out
I have 2 questions for you all.First one is about jetting,I have a 97 polaris scrambler 500 and i put a Aaen slip on pipe on it the factory jet is a 125.The altitude here is 1157 ft and temp can range from -15 to 100 in winter and summer and alot of humidity.I probly wont ride in that cold but somewhere in the range of 30 to 90F.What do you all recomend for jetting?Factory said 125 at 2000ft i t hink so if any of you have a jet calulator what would it recomend?2nd question is with tires I bought it used and it came with the right size tires on front but the back ones are making me wonder.I have a repair book for it and it calls for 24x11x10 but it has 23x11x10's on it and when i did a search on the net they all said 23x11x10's??Im confused on that one too.I counted the back sproket and it has the right amount of teeth for that year 98' hada smaller one but also says in book for 23x11x10's tires too.If any one know for sure could you please email me or respond back.It doesnt seem like its pulling(4wd) but I dont know..
Please help if you can,
Thanks
Old Jun 25, 2003 | 10:06 PM
NCScrambler's Avatar
23x7x10 on the front, 22x11x10 on the rear. The jetting you have is good, when it says 2000 ft, that means 2000 ft and under. If you go above 2000ft. the rule of thumb is one decrease in main jet size for each 200ft. rise in elevation. During the winter you normally have to jet up and in the summer jet down. That goes for about every 25 degree temp change go down on the main jet. If yours runs fine at the cold weather you spoke of, then as the weather warms up, you could go down one size on the main jet for each 25 degree difference.
Old Jun 25, 2003 | 11:35 PM
steve89's Avatar
Thanks for the quick reply.As for jetting it seem to run better now its hot out and humid out here but maybe its just the new pipe too.I will pull the plug and do a test to make sure but its so darn hard to to take everything off(plastic).As for the tires are u sure i had to looked in the book i have again(clymer) it says 1997-1998 rear tires 24x11x10 and says for sproket 38 for 97 and 36 for 98 and on.I did count it and there 38 there.If by the book then its 2 teeth to big or maybe its a type error.If any one eles has had or has a 97 could you tell me what the orignal tires for the back were?
Thanks again all
Old Jun 27, 2003 | 07:30 PM
steve89's Avatar
I found a site to confirm my question thanks
bafisher1986
Jul 21, 2015 04:12 PM
rcappie4
Jul 18, 2015 07:51 AM
Robinhood
Jul 13, 2015 09:13 PM
Edgeslade
Where to Ride
Jul 10, 2015 05:08 PM
