jetting 344R power valve
Old Jun 26, 2003 | 04:53 PM
344PV's Avatar
Default jetting 344R power valve
Anyone who is running Big bore PV's or none PV's just was wondering what jetting you are running i usally ride in glamis or sea level
Old Jun 27, 2003 | 12:28 AM
Mike330R's Avatar
I have the same motor and also ride at Glamis. I run a 188 main. It's a tad fat and would probably be OK with a 185. See what works for you by doing a plug check.
Pilot I use a 48 I belive.
Can't wait till October when it cools off!
Old Jun 27, 2003 | 12:04 PM
344PV's Avatar
Thank's Mike. Can't wait for october i might try some night rides out at glamis Probably next full moon the 13th.
Old Jun 27, 2003 | 12:15 PM
HA2's Avatar
HA2
334PV any pictures?
HA2's Avatar
HA2
Also, Id like see to how well the +4 over swing arm reacts in the dunes and at a hard launch. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jun 27, 2003 | 07:20 PM
344PV's Avatar
I will try and get some pic's next week, launching with the 4" over swing arm is not all that bad depending on which set of paddle tires i am using 20x10x8 (7 paddles) or 22x11x8 (8 paddels) both haulers. In the dune's 4" over is still ok but not nearly as fun as stock.
Old Jun 27, 2003 | 07:46 PM
HA2's Avatar
HA2
what do u recommend (swing arm) for a ported 310 86r ATC?? im running sand sharks on 10 inch rims dont know the exact specs.
Old Jun 27, 2003 | 08:58 PM
344PV's Avatar
? Do you Have the 310 in it now. If not I would Try it first to see if you like it. I had a ported 270 before with a stock swing arm.
Old Jun 27, 2003 | 09:33 PM
HA2's Avatar
HA2
right now its a mild port 248 and i have problems in 4th gear at the hill and thats with me straddling the tank. launching always is a scare and I cant imagine it with a decently ported 310. so it's a factor, +2 or +4. I will try stock for a while though.
Old Jun 30, 2003 | 09:22 PM
344PV's Avatar
I put some pics in my profile of my ATC
