Best Swingarm Skidplate?
Old Jun 29, 2003 | 09:59 PM
lilnotts's Avatar
Default Best Swingarm Skidplate?
I'm thinking about gettin the Pro Armor one and seems to be the best, wat do you all think?
Old Jun 29, 2003 | 10:16 PM
crashnburn's Avatar
I have a PRM that has taken some abuse and is holding up really well. The Pro Armor one looks good also.
Old Jun 29, 2003 | 11:15 PM
MudStud's Avatar
I have the Proarmor and Dont like it..
It's bottom bolts are not solid, they have like slide cut in them.. Ya know when you have just a drill hole for the bolt it does not allow it to slide.. well the bottom bolt is not just a hole, its like a track for the bolt.. but what happens if you ding it it hits your brake rotor... Mine has ben hit enough times that it has a groove in it for the brake rotor now...
it was easy to install. I personaly dont like Pro Armor, I got burned by them on some other things so due to that I would recomend PRM...
Old Jun 29, 2003 | 11:30 PM
lilnotts's Avatar
does anyone else not like the pro armor one?
Old Jun 29, 2003 | 11:32 PM
ATVMX's Avatar
im thinkin bout gettin a full skid plate set
what does everone recommend for the swingarm skidplates as well as the a-arm skidplates and motor/frame skidplates
some companies better than others for different parts?
any help would be greatly appreciated
thanks
rob
Old Jun 30, 2003 | 05:43 PM
TheSorb's Avatar
I've got the Pro Armor swingarm skidplate and so far it's great. Pro Armor makes their stuff from thicker aluminum than most of the others out there. I'm not familiar with PRM, but I can tell you that I'm very happy with mine. [img]i/expressions/face-icon-small-wink.gif[/img]
Old Jun 30, 2003 | 06:03 PM
pads's Avatar
The Pro-Armor is great. I had a Riccochet and it folded at Salamanca poker run. The Pro Armor is shaped differently so I doesn't bend and it takes quite a beating. It is also easy to install, you don't have to remove any part of the axle and it mounts right over top the stock nylon one. Therefore, there is great protection. It also has a place for a tow strap if you need to pull your buddies Raptor or Predator home or just drag a block behind you to slow you down so the other quads have a chance.
Old Jun 30, 2003 | 08:16 PM
MrMeaner's Avatar
Ive had a DG for over a year and its really nice. Dont get the Armadillo one it has a bar on the bottom and will grab stuff
STLyamwar
Jul 25, 2020 04:44 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
95wolv
Jul 21, 2015 12:25 PM
Dabears1983
Jun 23, 2015 04:59 AM
