Loose frontend
Old Jun 30, 2003 | 11:15 AM
slowmoTRX's Avatar
Default Loose frontend
Hi,I just bought an old 87'TRX fourtrax250 to do alittle trailriding with my friends and it needs a fair amount of work.I've already redone the back brakes,replaced the front wheelbearings,replaced the stuck choke cable,fibreglassed alot of the broken plastic and i've serviced it top to bottom.The bike runs well but the front end needs some attention.This model doesn't have a-arms like most other atvs' i've seen,it looks more like the frontend of a lawntractor or something.The wheel spindles have a greasefitting on the top and bottom and there is alot of play in there which allows the wheels to speedwobble at times.The balljoints don't look too bad so i assume the wobble is from the loose spindles.Can someone tell me if this setup can be rebuilt with bushings or bearings or do you have to buy the whole spindle to fix this problem,i hope it's not the later because i can imagine what Honda would charge for them.Any tips would be greatly appreciated.thanks.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
jankerstien
Sep 21, 2015 03:09 AM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
