Predator Faster Rev Mod
Old Jun 30, 2003 | 01:38 PM
modquad's Avatar
Default Predator Faster Rev Mod
Just a little performance quickie. The one-way clutch and the flywheel are held together by 8 m6-1.0 x16mm allen head bolts. Changing these out with Titanium units will save you upwards of 2 oz of rotating mass....may not seem like much, but try that at 9,000rpm. The m6-1.0x15mm (closest is 1mm shorter) bolts are presently on backorder with Mettec.com....you'd be in line behind me. You'll need the Polaris #PA-46075 flywheel puller, and make the change during an oil change, cause you're gonna have to drain the crankcase of oil....otherwise it'll be on the shop floor. There are also rotating clutch retaining bolts on the other side....haven't gotten to those yet, but I'll post when I do. [img]i/expressions/face-icon-small-happy.gif[/img]
Old Jun 30, 2003 | 02:36 PM
predator530's Avatar
i wonder if you can shave some weight off of the flywheel
Old Jun 30, 2003 | 04:22 PM
modquad's Avatar
Tapered socket head. If you want, you can wait til I get mine, then I'll do the final clearance checks. As far as milling the flywheel, that will probably surface later, as shops get more mods. I'll also post info on the clutch bolts when I get that side opened up and measured.
Old Jun 30, 2003 | 04:34 PM
modquad's Avatar
There are 8 bolts holding the flywheel to the starter ring gear.
Pgbama11
Jan 16, 2016 08:19 AM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Pgbama11
Sep 10, 2015 08:20 AM
Elkaholic
Sep 6, 2015 02:44 PM
