L&A Designs one-way for raptor
Old Jul 5, 2003 | 12:51 PM
warrior007's Avatar
Default L&A Designs one-way for raptor
For all those wondering - the L&A designs oneway will be available on July 14th.
Its a much simpler and more reliable design with each roller is double sprung on its own, I have had one for 2 months and about 300 starts without any problems or noise. L&A has been testing one for over 6 months now with no problems. I really like the fact that it is more like an actual bearing with rollers than yamaha's "oblong sprag" unit.
not only is it going to more reliable - it wieghs less than stock, a majority of the flywheel wieght is the one-way itself. This could net quicker revs off the line for those that have done everything else! I dont have a scale that precise but from the looks of it it is lighter - less rollers/sprags and extra holes drilled into the outer cage.
Old Jul 5, 2003 | 12:56 PM
Raptoryfn660r's Avatar
RIP Dear Friend
warrior007,
Do you have any suggestions on pro-longing the life of the one way bearing?
Mine is still original after over 2 years but I have always started in neutral.
Chet
Old Jul 5, 2003 | 01:04 PM
warrior007's Avatar
yep,
My friends are on their originals still, but mine was the oldest and took a while to get my jetting right, I had choke problems, bad plugs. All lead to less one-way life. I thoroughly trashed my old one from all this abuse.
The best bet is to richen up the idle circuit slightly (1/4 - 1/2 turn) and raise the idle just above 1500. The bike will start easier - prolonging the stockers life.
I also believe that leaving the bike in gear - like in the back of a truck and not tied down can put a beating on the one-way over time. The same goes for hillclimbing, I know when I do not make a hill I lean way up over the front and let the motor hold me there till I can get off and turn it around. sometimes if the motor is not on the compression stroke when this happens it spins backwards and I can hear the starter turning slightly so I know the one-way is engaged which can damage it aswell
Old Jul 5, 2003 | 01:32 PM
RIP Dear Friend
That's interesting because most of the time when mine is trailered I do put it in neutral because it seems that there would be stress on certain areas.
Thanks for the info.
Old Jul 5, 2003 | 03:07 PM
Ward660R's Avatar
Thanks for the info 007!!!
Any clue on who is going to be selling them?
Old Jul 5, 2003 | 03:52 PM
WallStreet's Avatar
How much? Warrior, I ordered my Yamaha oneway, gear, and gaskets shipped for 183. Thanks alot for giving me their number! So let me see if I have this right, to add life to my one way, start in neutral with clutch in. Do you give it any gas or choke it? I will no longer leave mine in gear when travelling. Thanks again.
Street
Old Jul 6, 2003 | 01:56 PM
FISHER1648's Avatar
Again, 007 is leading the charge in the battle to correct the problems with our Raptors !
Thanks dude !
My one way is still hanging in but I'm sure it's just a matter of time [img]i/expressions/face-icon-small-disgusted.gif[/img]
bmxatv10
Oct 14, 2022 06:23 PM
Sep 30, 2015 01:37 AM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
