swing arm bearing
Old Jul 5, 2003 | 01:50 PM
kvf400nbca's Avatar
Default swing arm bearing
The swing arm bearing are gone on my 2002 kvf650. They starte to make noise at 1500km now at 1700km there is nothing left on one side! the rear shock is also getting very weak. It wil need to be rebuild or replace at the same time the bearing are repaired. The bike will be out off order for at least 2 weeks or more depending on parts . Since a bought this think used last fall (with 1100km ) I had to replaced the choke cable & spring , I blew the belt, front brake pads are just gone, now rear shock and swing arm bearing. Not impressive, I would think twice before buying one again.
Old Jul 5, 2003 | 03:34 PM
nyroc's Avatar
Mine has over 2000km and Mainly just a belt. No brakes, no shock, no swingarm. Too bad, bad luck I guess.
Old Jul 6, 2003 | 11:42 AM
mastrblastr's Avatar
Cross reference your swingarm bearings and put in some aftermarket <u>SEALED</u> bearings. Kawie's design on the swingarm bearings is lame. Also, all you gotta do is get your rear shock recharged (as long as it is mechanically sound). If you want, you can get them to boost your pressure up to about 145 pounds to give you a little quicker rebound.
I have 1800 kms on my 650 and have had minimal problems. Guess you know why the guy you bought yours from sold it now!![img]i/expressions/face-icon-small-wink.gif[/img]!!
wendal
Aug 3, 2024 10:03 PM
exmotocrosser
Sep 13, 2019 06:12 AM
fd24
Jan 16, 2019 08:59 AM
jbrewster94
Sep 23, 2015 04:16 PM
Elkaholic
Sep 6, 2015 02:44 PM
