atv decals
Old Jul 6, 2003 | 10:41 PM
suds's Avatar
Default atv decals
My decals on my 2002 are getting a bit warn out. Anyone know of any good web sites out there where I can check out what type of decal kits are available out there for my quad.
Old Jul 6, 2003 | 10:45 PM
suds's Avatar
Default atv decals
and by the way, what is the difference between concentric drive and non concentric drive. thanx
Old Jul 7, 2003 | 12:20 AM
95sport400's Avatar
Default atv decals
Can't help you with the decals, but can on the concentric drive. On the concentric drive, the front sprocket and the swingarm pivots are on the same (or almost the same) axis. This means as the suspension travels, the chain length and tension stay nearly constant. On the old ones, as the suspension traveled, the chain would tighten and loosen. That's why the old style have such a loose chain. Many people unknowingly would tighten the chain like they were used to on a bike or other atv and end up breaking them. Concentric is definately better, but I'm on my third "old style" Polaris with no problems yet.
Actually, I can help a little on the decals. You can find the factory decals at Partsland
Old Jul 7, 2003 | 12:25 AM
GM's Avatar
GM
Default atv decals
Ok the concentric drive is where Polaris put the front sprocket on the same axis as the rear swing arm, thus making it where the chain has constant tension at all times. Someone fill in if I missed anything. Also, the only decals that I know of are Factory Effex, or you can get them from HotSeat which the only difference there is that Hot Seat has their name on it instead of Factory Effex. Hope this helps.
www.hotsearperformance.com
garret~
Bkeb
Aug 12, 2015 12:45 PM
truckracer
Apr 30, 2002 12:23 AM
Rob4092
Aug 6, 2001 10:26 AM
Racer18J
Feb 14, 2001 12:17 PM
BigRed450
Jun 21, 2000 07:50 PM
