new mojave tires
Old Jul 7, 2003 | 05:03 PM
hondareconguy's Avatar
Default new mojave tires
I'm looking to get some new rear tires on my mojave. I want a tire with a little more muddin ability. I don't want a pure mud tire. I was looking at the all trak or realtor. one more question how much will flipping the front wheels help. thanks
Old Jul 7, 2003 | 10:11 PM
mojavekid13's Avatar
Flipping the front rims makes a HUGE difference! I would recamend it 100%
Old Jul 8, 2003 | 06:15 PM
mojave250man's Avatar
try kenda bear klaw they r good i have them on my mojave and they r good in the snow mud and trail now they have 22-11-10 out so u can get them a little smaller.
1996 Kawasaki Mojave 250
dg bumper
K&N filter
13t 41t 11t Sunstar sprocket
RK 520x90 Chain
CR 80 Rental Bars
kenda bear klaws 22-12-10
Old Jul 8, 2003 | 06:16 PM
2000IAWarrior's Avatar
get all tracs seen them on a mojave b4 and it they make it rip.
Old Jul 8, 2003 | 08:50 PM
boob's Avatar
ive got spider tracs, there really beefy. theyre 22 x 12.5 x 10 the grip is awesome its like a 20 inch tire with 1 inch of tread top and bottom, they were like 50 i tihnk, took a while to get them mounted i had to go to 6 differant shops, stock rims
Old Jul 9, 2003 | 10:26 AM
whosyodady's Avatar
As you can tell, I am brand new to the ATV scene. What is Flipping?
2002 Mohave, stock-so-far.
Old Jul 9, 2003 | 04:16 PM
boob's Avatar
you take the front wheels off and turn them around and bolt them back up this will add atleasdt 1 inch to each side in width, i didnt do it because the stock valve stim comes in contact with the brake caliper so you can either ditch the idea or buy 2 new valve stems and take out the old stems and put these new stems in backwards, then drill a hole on the other side of the rim and put the 2 old valve stems in right side up, a little bit of work but not alot of money
Old Jul 9, 2003 | 08:56 PM
rockrider's Avatar
The stock tires suck, especally in the snow where they give little floatation. They only thing they have going for them is that they are light.
I wouldn't screw around with flipping your front wheels. It is a PITA plus the greater offset will put additional stress on your front wheel bearings. Fast Trekkers are good front tires, they are cheap, perform well and you can get 22-8-10's which really widen things out in front. For rear the Realtors would be nice. I've got Cheng Shin Wooly Booger copies that work fine, a bit heavier than stock but they wear like iron. Realtors would be higher performance.
Old Jul 10, 2003 | 12:04 AM
mojave250man,
Is the kenda bearclaw heavy, even though I have the mods on my mojave, I'm trying to not gain too much weight if possible. I like that they're gonna sell this smaller tire, is it out yet?
Old Jul 10, 2003 | 11:56 PM
there heavier then the stock tire but there 6ply and mine don't have one plug in it and my tires have lasted for 3 year with a beaten. yea i think the smaller one is outand i think they r lighter then then mine.
dg bumper
K&N filter
RK 520x90 Chain
CR 80 Rental Bars
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
