BACKFIRE ON DECELERATION
Old Jul 12, 2003 | 07:44 PM
ROCKSVFORCE's Avatar
Default BACKFIRE ON DECELERATION
I HAVE KFX 700 WITH ALIEN DUALS WITH QUIET CORES, STOCK JETS, 3 TURNS ON CARB AIR SCREWS, ( PER DMC ) AND I AM HAVING MILD BACKFIRING ON DECELERATION. THE PROBLEM WAS WORSE WITHOUT QUIET QORES AND WITHOUT AIR ADJUSTMENTS. I HAVE TIGHTENED ALL THE BOLTS ON THE EXHAUST BUT THE BACKFIRE CONTINUES. THE 700 RUNS GREAT AT THIS ALTITUDE ( DENVER, 6000FT ) ANY SUGGESTIONS?
Old Jul 12, 2003 | 07:51 PM
RacinJason's Avatar
DMC has the biggest bunch of retards working in thier tech dept..
Adjust a/f screw out another 1/4 turn, adjust the idle and give it a shot
continue until the pop is gone...
Old Jul 13, 2003 | 07:32 PM
THANKS FOR THE ADVICE. I WILL TRY THE AIR ADJUSTMENTS, BUT WHAT DOES ADJUSTING THE IDLE DO TO STOPING THE BACKFIRE?
Old Jul 13, 2003 | 08:23 PM
yettiatcpg's Avatar
think about it this way, if you let off the throttle then it closes the slides and sucks gas like a choke , and if the exaust is hot then it lites the residuale charge of fuel/air, thats what causes the back fire in the exaust. the more air in the exaust then the greater the chance of back fire.
Old Jul 13, 2003 | 09:13 PM
THAT I WHY IM JUST A NOVICE? I LEARN AS I GO AND HOPE NOT TO STEP INTO ANY LARGE HOLES. THANKS
ReconBayou
Oct 31, 2022 05:37 PM
fordfaithful21
Dec 7, 2015 05:52 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
alzgarvin
Sep 11, 2015 08:53 AM
Brandon400
Sep 7, 2015 12:20 PM
