what carb is better
Old May 17, 2000 | 03:16 PM
lipp's Avatar
I have a 99 sc 400 all mods except bigger carb. what is the diffrence bettwen 38 flat slide or pwk 39? I just need more. thanks
lipp
99 sc 400 rcr ful-mod
Old May 17, 2000 | 04:40 PM
talon400's Avatar
That is the same question I was going to ask!! Let me know what you find out. Thanks
Old May 17, 2000 | 05:02 PM
Mike Chero's Avatar
lipp,
Frankly the carbs are about the same. Both are larger flat slide carbs that will increase throttle response over the stock VM34SS. The 38 TMX has been out there a little longer than the 39 PWK. Also, due to its larger float bowl, the 39 PWK is recommended for the newer model concentric drive machines where as the 38 TMX can be fitted to all machines. I've heard that the 39 mm PWK is slightly easier to jet, but the 38mm TMX has been around so long that the jet settings are pretty well established.
Some aftermarket companies make a 42mm TMX (a bored out 38mm) which is said to provide serious top rpm gains.
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
