Bayou 300 4x4 clutch problem
Hello, I have an weird problem with the clutch or tranny. My atv has hard shift (shift lever is much harder to use) from time to time, this usually happens when I first time I go through the gears, after that it don't happen until I park the bike for a few hours. I also cannot chenge the gear when going down hill, the lever will not move at all, unless I use the brakes to take the weight of the atv. I am after having the clutch adjusted, If I follow the manual for correct adjustment, the hard shifting still occurs, but when I decrease it more, I can remove the hard shifting I get when I first use the atv, but I still have the problems when shifting going down hills. Anyone have any suggestions.
