Sport Quads Discussions on sport quads.
new yfz450 header glowing
Old Jul 14, 2003 | 01:06 AM
erich's Avatar
Default new yfz450 header glowing
Just picked up the new yfz450 yesterday and the header pipe glows bright red. i know most big 4 strokes glow al little but this thing GLOWS you can almost see through it. The whole pipe has already turned blue. Its backfiring alittle too. To me it sounds like its running lean. Other than that it runs great, very fast. If anyone else has seen this yet please reply, im going to run it by the dealer tomorrow. As soon as the aftermarket pipes, etc. are available its going to be rejetted anyway.
Old Jul 14, 2003 | 11:35 AM
sickmojave's Avatar
sounds like it is really running lean [img]i/expressions/face-icon-small-wink.gif[/img]
Old Jul 14, 2003 | 07:42 PM
FTZLT250r's Avatar
Check your plug as soon as possible and richen it up.
Old Jul 16, 2003 | 02:53 PM
DuneMe's Avatar
My neighbor / friend had the same issue when they brought theirs home. I guess the dealer re-jetted it but, sounds like this may be a hot running quad.
Old Jul 17, 2003 | 02:32 AM
CroBiker's Avatar
i have a 4 stroke and the headpipe doesn't glow at all. if it's bright red then there's definately someting wrong with it.
Old Jul 17, 2003 | 03:08 AM
dork's Avatar
there's nothing wrong with your headpipe. while your motor may be running lean, its completely normal for the head pipe to glow red, especially when your sitting still. my yz426, my buddys yz450 and cr450 all do it. these motors put out a lot of power and make alot of heat.
Old Jul 17, 2003 | 04:37 PM
savethedesert's Avatar
there is nothing the matter with your quad at all. i have a yz250f and it glows bright red somtimes even blue when my bike is just sitting still idling. and my friends 2003 yz450f does the exact same thing. once you get going and the air gets flowing everything will go away.
Old Jul 30, 2003 | 01:51 AM
ridnwarrior's Avatar
If your headpipe is glowing red that means your exhaust valves are doing the same! Richen that thing up before you need to replace the valves. Anyone else that has a glowing headpipe should do the same. That is not normal. It is a sign something is wrong.
Old Jul 30, 2003 | 09:43 AM
dork's Avatar
ridnwarrior, try starting your yfz up at night time and take a look at the header pipe where it comes off the motor. i bet you'll see a cherry red pipe within a few minutes of running.
Old Jul 30, 2003 | 12:44 PM
HA2's Avatar
HA2
what octane are you running?
