belt adj.
Old Jul 15, 2003 | 02:33 PM
sledgehammer650's Avatar
Default belt adj.
I have read so many things about belt adj. but i was just wondering has everyone came up up with a idotproof way to check the measurement @ 13lbs of pressure. I use a fish gauge to check it now but, i wish i had a better way. Any homemade tools? Pic's of of such a tool would be outstanding. Thanks!!
Old Jul 16, 2003 | 01:36 PM
Default belt adj.
Guys is there an easy way to get the right tension on the drive belt? Help ive already got grooves in the clutch and need to get another and wanted to make sure that the belt is set prefect
Old Jul 16, 2003 | 02:02 PM
nyroc's Avatar
Default belt adj.
Try lifting a 12lb dumbell with one finger to get the "feel" and then push with that same pressure right afterwards on the belt.
Old Jul 16, 2003 | 02:07 PM
Default belt adj.
will that be close enough for something that pulling al that weight and cost so much to replace?
Old Jul 16, 2003 | 02:55 PM
nyroc's Avatar
Default belt adj.
Yes, if you are reasonably sensitive you will get it close enough.
I made mine just a little tight that way, but it worked out fine.
You could get it a little loose too, I suppose.
If you don't want a fish scale, or a belt tension meter, you may have to use the dumbell method.
Jeff Roper
Feb 1, 2022 11:48 AM
buddieboy
Dec 9, 2016 05:50 PM
hueby
Nov 6, 2015 11:34 AM
Jeff Roper
Sep 21, 2015 02:11 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
