I need front rims!! Help.
Old Jul 16, 2003 | 05:40 PM
PUSHINTHELIMIT's Avatar
Default I need front rims!! Help.
Does anyone have any DECENT front rims for a DS650? I would prefer the baja one with the rings but does ANYONE have any good front rims for a DS? I guess I would settle for stock front ones if they are in GOOD shape... I bent one rim severly and put 'er in the pickers after I smoked a F#ckin rock!!![img]i/expressions/face-icon-small-mad.gif[/img] Thanks.
Josh.
Old Jul 16, 2003 | 05:46 PM
I also heard you can use 400EX front rims on a DS if the holes are drilled out bigger or something... Is this true? If it is then I would be interested in a pair of 400EX front rims.
Old Jul 16, 2003 | 05:57 PM
RacinJason's Avatar
If it is true about the 400ex rims let me know
Old Jul 16, 2003 | 07:54 PM
Can someone please tell me at least if 400EX rims can work? I know you have to do something like drill the holes bigger or something but I need to get something rollin here. Thanks.
Old Jul 16, 2003 | 09:51 PM
RacinJason's Avatar
Pushin...do you know the wheel pattern for your fronts?
Old Jul 16, 2003 | 09:52 PM
lilnotts's Avatar
pushin, yes they will work but you'll need to do some take a file to the rim near the lug holes along the inner ring, if you look at your rims you'll notice that the stock ones have a curve where they would hit the hub, if you want me 2 show u a picture of where i'm talkin bout just give me ur email, i tried this wit my buddies ex front tires
Old Jul 16, 2003 | 10:49 PM
Thanks lilnotts! So I just have to do a little grinding on the inner wheel so it don't hit the hub. I got it, but is the bolt pattern the same? Will it just bolt right up after I grind the inner piece down? Unless I can get some DS650 rims for a good price I will get some 400EX rims because I should be able to get them cheaper anyway from a friend that has Honda parts up the ***!!!....... Wait, raptorjay has some 400EX wheels.....
Old Jul 16, 2003 | 11:21 PM
lilnotts's Avatar
the bolt pattern on the honda fron is 4/144, which is wat bomb tried to do but ended up wit 4/143, but the bolt holes line right up with the bomb hub, i tried this wit my buddy (yellowexracer) rims, he has stock rim and itps both hit in the same spot, when you try to put them on you'll see exactly wat i mean,
Old Jul 16, 2003 | 11:48 PM
Thanks man![img]i/expressions/face-icon-small-happy.gif[/img]
Old Jul 17, 2003 | 01:07 AM
lilnotts's Avatar
no prob, actually i was gunna compare his holeshots to my stockers to see how much better they were but the rim didn't fit, i was like ****
